shaneast1
#1 Posted : Sunday, October 4, 2015 8:08:29 AM(UTC)
shaneast1
Range ran in self clean and now display is out. I have found most common reason is the high limit thermostat. I am ordering that (8300802) as well as the blower, as most people have said that is a reason for the overload to go out. My question is should I get resistance on the other thermostats behind the front panel. There are two and one of them does, the other (9759944) does not. I'm not sure what this controls and if it is working or not, so I'm not sure if I should order a replacement.
Thank you.
#2 Posted : Sunday, October 4, 2015 10:42:03 AM(UTC)
Parts for Whirlpool GW395LEPB00 Range - AppliancePartsPros.com
I only see 3 thermal devices in the unit.
Item 16 in section 01 of the parts should be the fan control thermostat. it should be open at room temperature.
The other two (items 23 and 37 in section 03) should be the thermal switch and the thermal fuse, both should be 0 ohms.
If the fuse is gone I would also replace the switch.
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
No Display or Oven Light - GE Monogram ZGP304NR4SS (Oven Repair (including Ranges and Cooktops))
by Furgus 8/22/2021 10:11:09 AM(UTC)
GE Profile PSRS6PGZADSS No Lights, No Display Panel (Refrigerator & Freezer Repair)
by ablundon 5/5/2021 10:43:50 AM(UTC)
Fridge not working, No cooling, and no display (Refrigerator & Freezer Repair)
by thepr1nter 1/13/2021 8:22:08 AM(UTC)
Thermador double oven no display (Oven Repair (including Ranges and Cooktops))
by daiwa0411 10/8/2020 7:12:03 AM(UTC)
No Display, but Oven works and buttons beep (Oven Repair (including Ranges and Cooktops))
by kevinlampert 10/5/2020 2:11:56 PM(UTC)
Samsung DV42H5200EW/A3 No Display (Dryer Repair)
by caveman61 7/18/2020 7:28:59 AM(UTC)
Whirlpool Duet-No Display or Button function (Dryer Repair)
by floatinghead 6/8/2019 6:55:48 AM(UTC)
Not heating/No Display until burner switch turned on (Oven Repair (including Ranges and Cooktops))
by MattoxL 2/7/2017 6:16:27 PM(UTC)
Jenn Air Combination Wall Oven - NO Display?? (Oven Repair (including Ranges and Cooktops))
by jtharmon 12/19/2016 5:06:52 AM(UTC)
No display (Oven Repair (including Ranges and Cooktops))
by bartbill 11/16/2016 10:51:46 PM(UTC)
GE Refrigerator - No display indicator and cooling (Refrigerator & Freezer Repair)
by coolvir 11/15/2015 6:49:44 PM(UTC)
No Display (Oven Repair (including Ranges and Cooktops))
by gschvach 9/20/2015 5:57:03 AM(UTC)
Samsung Range no Display (Oven Repair (including Ranges and Cooktops))
by Windy_City_Lee 9/19/2015 12:59:11 PM(UTC)
