Our He LG clothes washer has started leaking whenever we do a load of wash. We have checked the drain, which is NOT clogged with lint or anything else. Has anyone else encountered this problem? If so, is there an economical DIY solution? And how does one do this? It's an LG TROMM WM2277HW washer between 5 and 10 years old.
THANKS!
Operate the machine with the bottom panel off and see if you can locate the source of the leak. Most of the time it would involve the rubber gasket around the opening, but check the drain hoses from the tub also.
