Denarae
#1 Posted : Tuesday, August 4, 2015 7:21:30 AM(UTC)
Denarae
I bought this washer used and It will fill and you can hear the agitator moving but it does not move in the tub. it will drain and spin. I took the top off and noticed that there are four rubber straps that hold the tub in place and that three of them are broken if I replace these will it help or is the washer toast?
CletusT
#2 Posted : Wednesday, August 5, 2015 11:04:14 AM(UTC)
CletusT
It could be a few different things, but the straps do need to be replaced.
The drive bell under the agitator could be stripped, bolt could be loose or broken, the drive coupler on the motor could be broken, or the belt off.
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
Estate Washer wont spin, not the coupling (Washer Repair)
by Greenday1827 2/28/2014 3:55:12 PM(UTC)
