Bottom freezer fridge by Samsung model RB215LASH The top fridge part seems to stay at a constant 36 degrees all day. The bottom freezer stays around 24 to 34 degrees. I checked the condenser fan and it seems to be running cycling on and off all the day, so I assume it's working.
Do you think it maybe the start relay?
Also the fridge (top part) makes a rumbling sound on the back which is intermittent.
Thanks for your help. -Al
You have been a member since:: 2/29/2008(UTC) Posts: 19,638
THIS FORUM IS DEAD!!!!!!! |
Thanks denman. I did check and the bottom freezer back wall is frosted. I did the self diagnostics as you suggested and it shows: R- Defrost error and C-Fan Error.
Which parts do do you think need to be replaced? thanks, much appreciated.
The C-fan is probably the condenser/compressor fan so check that it is running OK.
I am not sure what R-Defrost error means. I think the R is the refrigerator side (fresh food). I would remove the cover and check that the evaporator coils are not iced/frosted over heavily. |
