spawnie69
#1 Posted : Tuesday, July 21, 2015 4:15:39 PM(UTC)
spawnie69
Bottom freezer fridge by Samsung model RB215LASH
The top fridge part seems to stay at a constant 36 degrees all day.
The bottom freezer stays around 24 to 34 degrees.
I checked the condenser fan and it seems to be running cycling on and off all the day, so I assume it's working.
Do you think it maybe the start relay?
Also the fridge (top part) makes a rumbling sound on the back which is intermittent.
Thanks for your help.
-Al
#2 Posted : Wednesday, July 22, 2015 1:53:00 AM(UTC)
Parts for Samsung RB215LASH Refrigerator - AppliancePartsPros.com
Here is a service manual. Your unit may not be an exact match but it should be close.
http://appliancejunk.com...&id=395;t=1437558319
You will have to join the site and be logged in.
I doubt the problem is related to the compressor as it is cooling.
Remove the covers in the freezer and check the evaporator coils.
If they are heavily iced/frosted over it could be a defrost problem.
Also try running the diagnostics to see if a fault comes up.
spawnie69
#3 Posted : Monday, July 27, 2015 9:50:28 AM(UTC)
spawnie69
Thanks denman.
I did check and the bottom freezer back wall is frosted.
I did the self diagnostics as you suggested and it shows:
R- Defrost error
and
C-Fan Error.
Which parts do do you think need to be replaced?
thanks, much appreciated.
#4 Posted : Wednesday, July 29, 2015 2:00:44 AM(UTC)
The C-fan is probably the condenser/compressor fan so check that it is running OK.
I am not sure what R-Defrost error means.
I think the R is the refrigerator side (fresh food).
I would remove the cover and check that the evaporator coils are not iced/frosted over heavily.
