Tom Lee
#1 Posted : Monday, December 17, 2007 8:23:22 AM(UTC)
Tom Lee
After filling all the machine does is hum. I traced the humming to the motor. I can manually turn the motor by pulling the belts and everything seems to be free.
Is there anything else I could check to make sure I don't have to replace to motor? ($100+)
#2 Posted : Monday, December 17, 2007 6:01:36 PM(UTC)
The first thing I would do is remove the belts from the motor pulley and check how it works without belts.
Check wires and wires connection to the motor.
kawfeeman
#3 Posted : Tuesday, December 18, 2007 4:50:21 AM(UTC)
kawfeeman
maytag used to have a start cap you could add to the motor to help give the motor a little extra push,but you are probably better off replacing the motor if it is indeed bad..
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Fan motor replacement manitowoc (Refrigerator & Freezer Repair)
by Guest 5/27/2023 4:35:45 AM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
Samsung dv40j3000ew/a2 wont start after motor replacement (Dryer Repair)
by rev1id 3/24/2021 7:38:30 PM(UTC)
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 10/26/2018 8:36:20 AM(UTC)
Washer wont drain, after motor replacement (Washer Repair)
by rweltz 6/15/2018 4:41:50 AM(UTC)
Dryer Motor Replacement - wiring (Dryer Repair)
by houkden1 1/9/2018 5:12:44 PM(UTC)
PYG2300AWW Motor Replacement (Dryer Repair)
by headmotty 2/27/2017 10:02:59 PM(UTC)
GE dryer Motor replacement (Dryer Repair)
by etshome 7/23/2015 12:50:21 PM(UTC)
by Washington3 2/6/2015 7:42:48 AM(UTC)
Found extra part during pump/motor replacement (Dishwasher Repair)
by msg1524 11/1/2014 10:27:19 AM(UTC)
dispenser motor replacement (Refrigerator & Freezer Repair)
by pusser 8/31/2014 5:05:31 AM(UTC)
LG drain motor replacement (Washer Repair)
by Kim KS 6/13/2013 5:52:23 PM(UTC)
Kenmore Ultra Wash Motor Replacement - need Serivce manual (Dishwasher Repair)
by GlennFord 4/14/2013 1:03:22 PM(UTC)
Auger Motor Replacement (Refrigerator & Freezer Repair)
by millhouse 12/19/2012 4:20:29 AM(UTC)
