Hello, I have a Samsung WF448AAP/XAA-0000 that still wont drain after I replaced the drain motor, control board, and the door latch. Not sure what to replace now. It still will not finish the cycle and drain. I guess my next step is to replace the front control panel. any other help would be greatly appreciated!! Thanks, Rich
can anyone help me out??? I got a te fault code in the terst mode, and it said it was the Thermister, so I replaced that also, and it still gives me the code. Any help??? Thanks,
can anyone help me out??? I got I te fault code in the terst mode, and it said it was the Thermister, so I replaced that also, and it still gives me the code. Any help??? Thanks,
i had a washer that was not draining before and i found out there was some stuff stuck in the drain line.. once i cleared it everything worked fine. if you haven't already check to make sure nothing is clogging or blocking the drain line.
