jamesm113
#1 Posted : Tuesday, June 23, 2015 9:13:55 PM(UTC)
jamesm113
Hello,
I have a 2000 model Frigidaire front washer that has been intermittently not performing the spin cycle.
Instead it will tumble the load until the buzzer sounds. Sometimes there is still water in the drum.
We're able to get around the issue by re-setting the timer to the final spin cycle and after 1-2 tries, it will work.
Any ideas?
Thank you!
Simon / APP Team
#2 Posted : Wednesday, June 24, 2015 2:53:48 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You may have a problem with a slow drain. You have mentioned that water stays in the tub after the end of the cycle. You need to check the drain hoses and the drain pump for clogs. Unplug the washer and remove the kick panel (two screws at the bottom of the kick panel). Take off the big hose connecting the tub and the pump and clean it out.
Part number: AP2107618
Ignore the video it's being removed.
Also check the pump inlet and impeller for debris.
Here are the breakdown diagrams and parts list for your washer
Model FWT647GHS0
Good luck. Please post the results.
Thank you,
Simon.
jamesm113
#3 Posted : Monday, August 24, 2015 4:31:11 PM(UTC)
jamesm113
Hi Simon,
Sorry for the delayed response. I pulled all the hoses & drain pump, but found no clogs. After cleaning them out (there was some amount of stuff in them), the issue still persists. What's the next thing to try?
Thanks,
James
jamesm113
#4 Posted : Friday, November 20, 2015 12:24:02 PM(UTC)
jamesm113
Hi Simon,
Any ideas?
Thanks,
James
