mservice
#1 Posted : Saturday, February 7, 2015 9:23:30 AM(UTC)
mservice
I have a WHIRLPOOL 30" Slide-In Electric Range
Model # GY397LXUB03
Serial # D24060805
The numbers 1, 2 & 7 have stopped working on the touchpad. All other functions appear to work properly and the oven does come on / timer works, etc.
Is this as simple as replace the touchpad switch membrane - Whirlpool W10207928 Swtch-Memb - AppliancePartsPros.com or is there the potential of others issues?
If potential of other issues how would I test / diagnose?
Also - part is about $20.00 less from ******************************** http://www.********************...GY397LXUB03/1198/0124160 - will AppliancePartsPro match price?
Thank You
#2 Posted : Saturday, February 7, 2015 2:41:47 PM(UTC)
[COLOR="Blue"]If potential of other issues how would I test / diagnose?[/COLOR]
There is always a possibility that the control board is the problem but the membrane switch is more likely.
There is no way to check it as I cannot find a pin out for the panel so you cannot check it.
If you purchase it from AppliancePartsPros and it does not fix your problem you can return it. Please see their return policy.
Perhaps the following might work at least it is worth a try.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
mservice
#3 Posted : Thursday, February 19, 2015 9:48:46 AM(UTC)
mservice
OK - so had to replace the touchpad AND the control board - now oven will not go over 205 degrees -
Oven heating up was never issues previously / before replacement of touchpad / control board.
Ideas?
Do you have a link to the wiring diagram?
#4 Posted : Friday, February 20, 2015 1:24:38 AM(UTC)
If the unit shows that it is ready then check the oven sensor resistance.
Should be about 1100 ohms at room temperature.
If the unit stays in pre-heat check the wiring.
Check the oven elements.
Check the hi-limit ( should be 0 ohms).
If all )OK odds are that you received a bad board.
File Attachment(s):
GY397.pdf (132kb) downloaded 4 time(s).
mservice
#5 Posted : Friday, February 20, 2015 1:39:49 AM(UTC)
mservice
Thanks -
Oven does NOT say it is ready - just never reads more than 205 degrees
Will check items
How would I start an RMA for the bad board?
#6 Posted : Friday, February 20, 2015 6:12:20 AM(UTC)
I do not know.
I do not work for AppliancePartsPros.
