Pete11
#1 Posted : Tuesday, January 27, 2015 8:23:19 AM(UTC)
Pete11
Folks,
My fridgidaire classic series electric range is not working. Heard a loud pop and it lost power. Now, its not even powering on.
Would appreciate some feedback on what to do.
Thanks,
#2 Posted : Wednesday, January 28, 2015 12:36:12 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Frigidaire FEF366CCF Range - AppliancePartsPros.com
Do the stove top elements work?
Does the oven light work?
If nothing at all works on the stove then it is probably a power problem.
But before even checking that see if you can find out what the pop was.
Unplug the unit when doing this.
Check that the bake and broil element coating is OK.
Check that the control board is OK.
Check that the wires in the unit are OK pay special attention to the ones associated with the oven elements.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
