chrisw73
#1 Posted : Saturday, January 24, 2015 5:09:15 AM(UTC)
chrisw73
Dryer was running fine and when I went in to check on some bedding that was being dried I noticed it wasnt quite dry and the dryer itself was very warm. I added time to the cycle and hit start and the unit just "clicked". Hit it a few more times and again just clicks. All lights and timer are on. If I wait about 30-45 minutes it will once again run and do about a cycle before it gets to warm and the same thing repeats.
I pulled the dryer out and vacuumed out the exhaust and cleaned out the outside vent. Tested to see if the dryer exhaust was working and it is blowing strong from the dryer when it runs.
Any thoughts?
chrisw73
#2 Posted : Saturday, January 24, 2015 7:15:38 AM(UTC)
chrisw73
Just to add, I started a test cycle a few minutes ago and went to the outside vent to ensure it was venting fine all the way out and it is blowing plenty of warm air to the outside.
Whirlpool Duet electric dryer overheats despite replacing various parts (Dryer Repair)
by Manec 8/18/2016 6:49:44 PM(UTC)
dryer overheats/shuts off (Dryer Repair)
by texasoutcast 6/24/2015 7:01:12 PM(UTC)
Electric Dryer overheats and blow thermal fuses (Dryer Repair)
by hall9107 1/29/2015 10:04:39 AM(UTC)
Dryer overheats when vent is connected (Video) (Dryer Repair)
by shosterman 4/14/2014 10:05:35 AM(UTC)
Old Whirlpool Dryer overheats (Dryer Repair)
by cappy3 8/3/2013 9:43:26 AM(UTC)
by reprice 11/12/2012 3:44:31 PM(UTC)
Dryer overheats. (Dryer Repair)
by schigara 5/23/2012 1:14:30 PM(UTC)
dryer overheats (Dryer Repair)
by 2501329 4/19/2012 9:05:52 PM(UTC)
dryer overheats/quits (Dryer Repair)
by belindaculwell 11/29/2010 5:12:11 AM(UTC)
Dryer overheats after all thermostats replaced (Dryer Repair)
by Dana-T 9/2/2009 6:44:40 AM(UTC)
by longdestent 5/29/2009 9:15:49 AM(UTC)
dryer overheats, blows thermal fuse (Dryer Repair)
by netsteeler 5/29/2009 8:33:13 AM(UTC)
Dryer overheats on auto dry cycle (Dryer Repair)
by hicks115 4/19/2009 9:56:34 AM(UTC)
knmore dryer overheats (Dryer Repair)
by kenmore broken 10/25/2008 11:26:01 AM(UTC)
Gas Dryer Overheats & Shits Off after 10 mins (Dryer Repair)
by crs2007 4/30/2008 5:08:14 AM(UTC)
