AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Black marks on clothing & dryer squeals at times
I just unloaded a load of clothes and black marks were left on the clothing. On one dry fit shirt (1st time ever through the dryer) the athletic numbers on the back appears to have burn holes in it, along with the black marks. There is also some intermittent squealing, mainly on start-up.
Is it time for a new dryer? This one is 24 years old.
Thanks!
Here are your parts Parts for Maytag DE4000 Dryer - AppliancePartsPros.com[COLOR="Blue"] Is it time for a new dryer?[/COLOR] I cannot say depends on the following: Are you happy with it How much is it going to cost to fix What kind of shape is it in. I can tell you that the new units will not be built as good as this one. If you have to pay someone to do the work it is probably not worth fixing. Sounds like the clothes are getting between the the drum and the units frame. Could be a number of things, you will have to open it up and check. The drum seals. The front support bearings (item 22 in section 07). The rear support wheels. You may as well give it an overhaul while you are at it so also check the belt, idler wheel etc. etc. When working on a dryer it is a good idea to check/clean your vent system unless you are doing this yearly. |
THIS FORUM IS DEAD!!!!!!! |
I'm happy with it, and I can repair it. Now, is she happy with it.....that's another story. Yes, I, too believe the clothes are getting caught between the drum and the frame. So, the parts you listed should take care of this?
Thanks!!
[COLOR="Blue"]So, the parts you listed should take care of this?[/COLOR] Yes they should but I would take it apart before ordering just in case there is something else that needs replacing. |
Thanks! I'll have a look at the this afternoon.
Definitely needs glides. One glide glided right off of the dryer! I picked up the parts today, and should be back in business in the AM. Thank you!!
Glides installed this morning. All is well. Thank you again!:D
A little over a year later and another glide slid off. Do I need to change more parts, than just the glides?
Thank you
I cannot say without actually being there.
If the drum rotates fairly easily and everything looks OK then I would say that the drum mounts etc are OK.
Sorry for the delay in getting back to you but I am no longer an active member on this site. |
I work on dryers quite a lot and the glides dont normally come out of position until they are worn quite badly. If this one was replaced before and the other one is still OK then the drum is not running true in its rotation. This happens on some dryers when the seals are bad and the drum support rollers are not holding it in proper alignment. On a dryer the roller and/or its bearing that is above the heating tube or element is quite often worn before the opposite side due to the lack of lube or just plain worn out. Sometimes when I take these apart the shaft that supports the roller is also worn badly. Fortunately on the old Maytags the shaft is also replaceable. Hope this helps. These old Maytags are easy to fix and it is a question of how much money you want to spend. As a matter of interest last fall I bought, cleaned and resold a gas Speed Queen that was 41 years old. It needed minor repairs !!!
Dryer Repair
