J-Bird-Medic
#1 Posted : Thursday, August 28, 2014 7:53:06 AM(UTC)
J-Bird-Medic
dryer will not stay running unless you hold the start switch/timer.
After a ton of reading It sounded like the centrifugal switch on the motor.
So I replaced the motor but no change.
(I have replaced the motor several times in the past so had warranty).
I believe I tested all components for continuity.
What else could it be on this model?
TIA for your time!
Jay
J-Bird-Medic
#2 Posted : Friday, August 29, 2014 5:41:33 AM(UTC)
J-Bird-Medic
Anyone?:confused:
fairbank56
#3 Posted : Friday, August 29, 2014 6:24:54 AM(UTC)
fairbank56
Has to be the motor or a problem with wiring/connections between timer and motor. Check yellow/black wire that runs from timer S terminal to motor connector. Look for broken wire, faulty terminal lug connection, corroded/burned terminal at motor connector.
Eric
J-Bird-Medic
#4 Posted : Friday, August 29, 2014 6:53:28 AM(UTC)
J-Bird-Medic
Eric
Will check it when I get home and report back. Thanks for the reply.
J-Bird-Medic
#5 Posted : Wednesday, September 3, 2014 8:33:35 AM(UTC)
J-Bird-Medic
Eric
yellow/black wire rubbed bare by the drum and shorted.
Spliced and wrapped the bundle of wire in tape to protect and reposition away from the drum
Thanks Eric, I now have a very happy wife and Im a super hero for a day!
J
Guest (6)
