mY DRYER would not stop running on the auto dry and wrinkle control settings, but it would dry. Now it won't dry on the times cycle. What parts do I need to fix this? Thanks for your help.
Joined: 2/29/2008(UTC) Views messages in topic : 19,638
Here are your parts includes a wiring diagram Parts for Maytag MDE2706AYW Dryer - AppliancePartsPros.comYou will have to do some troubleshooting as no heat can be caused by a number of things. It may or may not be related to your earlier problem of no timer advancing. Unplug the unit and check the heating element, should be around 8 to 12 ohms. Check the hi-limit thermostat, should be 0 ohms. Check the cycling thermostat BU to PU should be 0 ohms. |
THIS FORUM IS DEAD!!!!!!! |
