bigherb2
#1 Posted : Sunday, August 3, 2014 6:40:32 AM(UTC)
bigherb2
Please help....my compressor and the fan at the bottom both run but niether the fridge or freezer gets cold
bfridge
#2 Posted : Sunday, August 3, 2014 8:09:33 PM(UTC)
bfridge
When you say the fan at the bottom, do you mean the compressor fan?
First I would check to make sure that the condenser coils are clean. If they are dirty, they will not properly cool down and your fridge will not get cold enough.
Next, I would check to make sure that the evaporator fan inside your fridge is working. This helps to move the cold air around. At the same time you can check to make sure that there is no ice build up on the evaporator coils.
richappy
#3 Posted : Monday, August 4, 2014 1:52:06 AM(UTC)
richappy
If the compressor is warm and vibrating, you have a serious sealed system problem.
bigherb2
#4 Posted : Monday, August 4, 2014 4:58:08 PM(UTC)
bigherb2
The fan in the fridge will not come on.I unpluged the fan and put my dc volt meter on the 3prongs ....I believe the top two gave me like 98 volts dc when I shouldve had like 13
bigherb2
#5 Posted : Monday, August 4, 2014 4:59:54 PM(UTC)
bigherb2
My coils look clean but I will spray them with coil cleaner.but my fan inside the fridge wont come on
bigherb2
#6 Posted : Monday, August 4, 2014 5:02:18 PM(UTC)
bigherb2
The evap. Fan wont come on .I read somewhere to check voltage at the j2 pin but no where on the motherboard can I find a j2 pin
bigherb2
#7 Posted : Monday, August 4, 2014 5:03:12 PM(UTC)
bigherb2
How would I fix a serious sealed system problem
richappy
#8 Posted : Tuesday, August 5, 2014 12:47:40 AM(UTC)
richappy
That problem makes the fridg terminal unless a real expensive one.; should confirm first.
