trisha57
#1 Posted : Monday, April 28, 2014 10:23:33 AM(UTC)
trisha57
My breaker tripped then reset breaker now oven will not heat. temp light works put it on clean It will lock but will not heat all top burners work fine.
#2 Posted : Tuesday, April 29, 2014 3:19:34 AM(UTC)
Parts for Frigidaire FEF352DSA Range - AppliancePartsPros.com
I am assuming that the oven stays in preheat and never comes ready.
Odds are that the control board (item 20 on section 03) is toast.
I would check the wiring to it and to the oven elements before replacing it.
You may also need a new overlay. They are peel and stick and often get damaged trying to remove them from the old board. Heating it up with a hairdryer helps in removing it.
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Frigidaire Oven won't heat (Oven Repair (including Ranges and Cooktops))
by scaredidiot 12/23/2010 6:40:55 AM(UTC)
Frigidaire Oven Won't Heat model ES510 (Oven Repair (including Ranges and Cooktops))
by SouthernCook 7/3/2009 5:13:03 PM(UTC)
