My breaker tripped then reset breaker now oven will not heat. temp light works put it on clean It will lock but will not heat all top burners work fine.
Here are your parts Parts for Frigidaire FEF352DSA Range - AppliancePartsPros.comI am assuming that the oven stays in preheat and never comes ready. Odds are that the control board (item 20 on section 03) is toast. I would check the wiring to it and to the oven elements before replacing it. You may also need a new overlay. They are peel and stick and often get damaged trying to remove them from the old board. Heating it up with a hairdryer helps in removing it. |
THIS FORUM IS DEAD!!!!!!! |
