Mandirigma
#1 Posted : 11 years ago
Mandirigma
Hi everyone. I've been reading and searching to find out why my fridge and freezer won't get cold. I got this fridge from a friend that was moving. It hasn't been used for 2 months. I plug it in, the evap fan kicks on, compressor starts running, fan to circulate inside is running. Capacitor looks new, relay makes no noise when shook. Tested compressor, reads .00,.00&.01 on the terminals. The service mood says everything is fine. It has refrigerant, no leaks. Is there anything else I can test and how? Any info or recommendation's would be much appreciated. Thank you for your time.
richappy
#2 Posted : 11 years ago
richappy
If the compressor is vibrating, but the condenser coils in the back are not hot, you have either a clogged capillary tube, or no refrigerant.
Mandirigma
#3 Posted : 11 years ago
Mandirigma
The compressor hums and slight vibration. It sounds like the compressor won't kick to push anything. Is there a way to unclog it? It has refrigerant. Thank you for your help. It's much appreciated.
richappy
#4 Posted : 11 years ago
richappy
Try a new start device on the side of the compressor, might fix it.
Mandirigma
#5 Posted : 11 years ago
Mandirigma
I'm curious. Should the suction side be hooked to anything or just crimped.2014-03-23 15.14.01.jpg
Mandirigma attached the following image(s):
fridge & freezer not getting cold (Refrigerator & Freezer Repair)
by Ricky2012 13 years ago
