I am not sure why the timer will run for 10 minutes and then stop.
Would be a good idea to check the power.
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK .
Unplug the unit ans set the timer to mid scale heated timed dry cycle.
Attach (tape or clip) one meter lead to L1 either at the line cord prong and leave it there.
Set your meter to it's most sensitive resistance scale. It is also a good idea to short the meter leads together before statin to see if there is a zero offset in the meter.
C and B connectors on the timer should be 0 ohms.
Both sides of the thermal fuse should be 0 ohms
4M on the motor should be 0 ohms.
5M on the motor should be about 1.5 ohms (motor windings).
White or white/red at the push to start switch should be about 1.5 ohms.
With the switch activated, black on the switch should be 1.5 ohms.
Keep the start switch activated.
With the door switch activated Common and Normally Open should be 1.5 ohms.
Keep this switch activated
The Neutral pron on the line cord should be 1.5 ohms.
The above is the entire motor circuit.
