rudekelly
#1 Posted : Wednesday, April 23, 2014 6:55:22 PM(UTC)
rudekelly
One day my dryer just didn't start. I changed the thermal fuse 1st and still didn't start. So I changed the high thermostat with thermal cut off thermostat kit. Still didn't turn on but when turn dial to timer I could hear ticking sound. So would it be the start button or settings knob or what? Clueless right now and dryers been out for almost year now.:confused:
#2 Posted : Thursday, April 24, 2014 2:56:49 AM(UTC)
Parts for Maytag AED4475TQ1 Dryer - AppliancePartsPros.com
[COLOR="Blue"]I changed the thermal fuse 1st and still didn't start.[/COLOR]
I am assuming that this was the one on the blower. It is in series with the motor.
[COLOR="Blue"]So I changed the high thermostat with thermal cut off thermostat kit.[/COLOR]
The above parts do not effect the motor. They do effect the heater and the timer motor when in timed dry.
[COLOR="Blue"]
Still didn't turn on but when turn dial to timer I could hear ticking sound.[/COLOR]
Does it advance?
Also check it in an auto cycle to see if the timer advances. Does it?
If the timer does not advance in an auto mode, check the heater with a meter. It should be around 8 to 12 ohms.
The reason is that you may have two problems in the unit, at least the symptoms point towards this.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
rudekelly
#3 Posted : Thursday, April 24, 2014 7:21:44 AM(UTC)
rudekelly
In timer mode it does advance and then it stops and no ticking after 10 minutes.
In auto sense dry cycle it does not advance and also no ticking at all.
rudekelly
#4 Posted : Thursday, April 24, 2014 7:23:09 AM(UTC)
rudekelly
Originally Posted by: denman Go to Quoted Post
[COLOR="Blue"]
Does it advance?
#5 Posted : Friday, April 25, 2014 3:44:20 AM(UTC)
I am not sure why the timer will run for 10 minutes and then stop.
Would be a good idea to check the power.
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK .
Unplug the unit ans set the timer to mid scale heated timed dry cycle.
Attach (tape or clip) one meter lead to L1 either at the line cord prong and leave it there.
Set your meter to it's most sensitive resistance scale. It is also a good idea to short the meter leads together before statin to see if there is a zero offset in the meter.
C and B connectors on the timer should be 0 ohms.
Both sides of the thermal fuse should be 0 ohms
4M on the motor should be 0 ohms.
5M on the motor should be about 1.5 ohms (motor windings).
White or white/red at the push to start switch should be about 1.5 ohms.
With the switch activated, black on the switch should be 1.5 ohms.
Keep the start switch activated.
With the door switch activated Common and Normally Open should be 1.5 ohms.
Keep this switch activated
The Neutral pron on the line cord should be 1.5 ohms.
The above is the entire motor circuit.
File Attachment(s):
AED4475.pdf (139kb) downloaded 1 time(s).
