Timothy Burt
#1 Posted : Thursday, April 10, 2014 12:02:47 PM(UTC)
Timothy Burt
Mom's dryer stopped heating. Checked the fuse box-OK, checked the fuse on the exhaust- seems OK, replaced the heating element and thermostat and still no heat. Dryer runs but no heat. Any suggestions? Was thinking of ordering other parts to replace and see if that does it.
#2 Posted : Friday, April 11, 2014 1:14:25 AM(UTC)
Parts for Roper RED4640YQ0 / - AppliancePartsPros.com
When you say "checked the fuse on the exhaust- seems OK", did you check it with a meter?
The first ting to check is the power. The heating element requires the full 240 volts.
If you place the timer mid-cycle, timed dry does the timer advance?
If not then you probably have a power problem as the timer also uses 240 in this unit.
If the power is OK then do you have a meter?
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
RED4640.pdf (197kb) downloaded 13 time(s).
Timothy Burt
#3 Posted : Friday, April 11, 2014 10:26:42 AM(UTC)
Timothy Burt
Thanks for the info. A ? though, how can you measure ohms and stuff without power to the machine? And when they say disconnect one side of the device to measure are they talking about the power cord to the block in the dryer?
#4 Posted : Friday, April 11, 2014 1:10:29 PM(UTC)
[COLOR="Blue"] how can you measure ohms and stuff without power to the machine?[/COLOR]
The meter has a battery in it. In resistance settings it creates a current through a part. It then measures this current and changes it to a resistance reading. An open circuit is infinite ohms. A closed/shorted circuit is 0 ohms.
A heating coil has some resistance so it usually measures about 10 ohms.
[COLOR="Blue"] And when they say disconnect one side of the device to measure are they talking about the power cord to the block in the dryer?[/COLOR]
When using a resistance scale the unit is always unplugged. If left plugged in then the line voltage is too high and it can blow the meter. The only power you want in the circuit is the power from the meter's battery.
But this is not what unplugging one side of a device when measuring it.
Lets say you are measuring a heater and there is another part wired in parallel with it so you measure across the meter and get 5 ohms this could be misleading. But if you disconnect one side of the heater then it is not part of a parallel circuit so you are measuring just the heater and then you should see the correct 10 ohms.
Note that there are lots of places to find info using a multimeter on the net.
Timothy Burt
#5 Posted : Tuesday, April 15, 2014 6:14:17 AM(UTC)
Timothy Burt
found out the timer is not advancing. what could i check next? could a circuit board be the prob? checked all with a meter and all is okay.
#6 Posted : Tuesday, April 15, 2014 8:14:49 AM(UTC)
[COLOR="Blue"]found out the timer is not advancing. what could i check next?[/COLOR]
I am assuming that it does not advance in timed dry as well as auto modes.
Could be a power problem.
In timed dry the timer motor circuit is: L2 , timer contacts F to T , Timer Motor , L1.
Set your meter to an AC volts scale.
Scale must be higher than 200 volts.
For instance on my meter I would use the 250 AC scale.
Remove the small cover on the back of the unit where the line cord attaches.
Measure From L1 (Black) to L2 (red) on the terminal strip you should have 240 volts.
Be very, very careful to not short out the meter leads to anything else!
240 volts is lethal!!!!
If unsure about doing this get an electrician or appliance repair person in.
If you have no voltage or 120 volts then you have to check the voltage at the wall receptacle or call in an electrician.
If you have the correct voltage, unplug the unit.
Set the timer mid scale timed try.
Measure across T to F on the timer using resistance, should be 0 ohms.
If not replace the timer.
[COLOR="Blue"]could a circuit board be the prob?[/COLOR]
No.
The unit does not have a circuit board.
see the wiring diagram I included in my earlier post.
LoriHubbard
#7 Posted : Monday, December 26, 2016 7:29:21 AM(UTC)
LoriHubbard
I read your blog but i can't understand that.
#8 Posted : Tuesday, December 27, 2016 1:50:09 AM(UTC)
If your model number is the same then the troubleshooting should be correct.
I do not know what part you are having a problem with.
Perhaps get a friend to take a look at it, often two heads are better than one.
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Speed Queen electric dryer no heat after 5 min. (Dryer Repair)
by napalm747 8/23/2014 6:05:30 PM(UTC)
electric dryer no heat - problem solved (Dryer Repair)
by JohnWMc 6/2/2014 3:17:26 PM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
whirlpool duet electric dryer no heat (Dryer Repair)
by Reisingera03 2/6/2013 2:49:42 PM(UTC)
by CSteidl 8/14/2012 11:59:05 AM(UTC)
by livetoride2112 3/5/2012 5:24:19 PM(UTC)
Maytag Neptune Electric Dryer No Heat (Dryer Repair)
by jrvier 11/12/2011 3:31:42 PM(UTC)
kenmore electric dryer no heat (Dryer Repair)
by vito m 5/18/2011 6:00:36 PM(UTC)
Sears Galaxy Electric dryer no heat,timer doesn't move (Dryer Repair)
by melindascrochet 5/2/2011 7:38:20 AM(UTC)
Whirpool Electric Dryer No heat (Dryer Repair)
by flmeade 9/14/2010 8:38:15 AM(UTC)
EstateElectric Dryer No Heat (Dryer Repair)
by elaza 6/5/2010 8:00:42 AM(UTC)
by STEVE8369 3/16/2010 3:53:24 AM(UTC)
by MIKEK38E 2/9/2010 5:25:07 AM(UTC)
Electric Dryer NO HEAT (Dryer Repair)
by powers7000 11/1/2009 10:47:38 AM(UTC)
