Reisingera03
#1 Posted : Wednesday, February 6, 2013 2:49:42 PM(UTC)
Reisingera03
Please help,
Dryer wont heat have replaced both hi limit thermostats twice coil heats to the point of burning out thermostats checked areas where lint builds up short of checking blower motor need suggestions
Thank you
Andrew
#2 Posted : Thursday, February 7, 2013 1:20:21 AM(UTC)
Parts for Whirlpool WED8300SW0 Dryer - AppliancePartsPros.com
See the attachment for your tech sheet
Not quite sure but I am assuming you have replaced the hi-limit thermostat and the thermal cut-off which are on the heater assembly, twice.
Below is my standard blub on this type of problem.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the thermistor on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to check the thermistor resistances.
File Attachment(s):
WED8300.pdf (411kb) downloaded 49 time(s).
Reisingera03
#3 Posted : Thursday, February 7, 2013 5:15:26 AM(UTC)
Reisingera03
Thank you for the response I will check all of those things tonight
