LindaGL
#1 Posted : Friday, March 21, 2014 8:03:19 PM(UTC)
LindaGL
The model number is noted incorrectly - it should be LE5800XMW0.
This dryer works without any problems in the timing mode - heating, drying and shutting off as it should.
In auto-mode (both regular and perm press), it heats and drys the clothes but the dial never advances and the dryer never shuts off.
What part am I looking at, how do I check it, and is it a DIY repair?
Thanks!
#2 Posted : Sunday, March 23, 2014 2:33:33 AM(UTC)
Below are your parts
Parts for Whirlpool LE5800XMW0 Dryer - AppliancePartsPros.com
I cannot find a wiring diagram for this unit so have to just give generalized info.
The timer is advanced differently for the two modes.
In timed dry it gets power directly from L1 (120 volts) to neutral.
In auto modes it gets power only when the heater turns off. This is L1 to L2 (240 volts) a resistor (item 5 in section 03) which reduces the voltage to 120 to advance the timer.
The first thing to check is the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time.
If OK, check the resistor. They are usually around 5,000 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
