2 Pages12>
cecildow
#1 Posted : Tuesday, February 18, 2014 7:30:35 AM(UTC)
cecildow
Just wondering if the door switch is bad will this also cause the light not to work aswell? Thanks
fairbank56
#2 Posted : Tuesday, February 18, 2014 10:51:17 AM(UTC)
fairbank56
Can't tell you without knowing the model number.
Eric
cecildow
#3 Posted : Tuesday, February 18, 2014 11:01:45 AM(UTC)
cecildow
8846291 Thanks
fairbank56
#4 Posted : Tuesday, February 18, 2014 12:09:15 PM(UTC)
fairbank56
That's not the model number. Should be a label with model number and serial number. May be under lid on panel rim.
Eric
cecildow
#5 Posted : Tuesday, February 18, 2014 12:47:04 PM(UTC)
cecildow
Hows 110 Thanks
fairbank56
#6 Posted : Tuesday, February 18, 2014 3:17:40 PM(UTC)
fairbank56
Still no good. If model number starts with 110. then it's made by Whirlpool but I already tried 110.8846291 and it doesn't come up. Is this a Canadian model? Usually,there's 11 numbers.
Eric
cecildow
#7 Posted : Wednesday, February 19, 2014 6:44:03 AM(UTC)
cecildow
Only other number on the tag is a ser#, I have tested everyting that I could and all is good but dont know how to test the timer. Is there a way to bypass the timer to see if this may be the problem? Its a Kenmore 60 series dryer. Thanks
fairbank56
#8 Posted : Wednesday, February 19, 2014 7:51:51 AM(UTC)
fairbank56
Can't help without the model number unless you can post hi-res photo of the wiring diagram. Should be inside the control panel or possibly inside the cabinet somewhere. Lamp does usually come off the door switch. Is the non operating lamp the only problem your having?
Eric
cecildow
#9 Posted : Wednesday, February 19, 2014 8:52:45 AM(UTC)
cecildow
Actually the dryer does not do anything so I was trying to check to most common thing that goes bad. I checked the door switch,thermal fuse,thermostat,start switch,breaker,the wall plug,the power cord,the motor,with a volt and ohm meter, I just dont know how to test the timer. here is a pic of the wiring and the model number. Thanks
cecildow attached the following image(s):
cecildow
#10 Posted : Wednesday, February 19, 2014 9:02:16 AM(UTC)
cecildow
A pic of the timer. Thanks
Guest (7)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Frigidaire Refrigerator LGHT1846QP1 - door switch and cabinet cooling (Refrigerator & Freezer Repair)
by BJPrice 10/26/2020 5:28:12 AM(UTC)
Maytag MVWC4658W2 Door switch? Will drain but not spin. (Washer Repair)
by JimAlbr 6/4/2020 5:49:53 PM(UTC)
Dryer keeps blowing the DOOR SWITCH?!?! (Dryer Repair)
by ppipowerclass 12/3/2017 12:54:14 PM(UTC)
Door switch (Dryer Repair)
by Hoglover 4/7/2017 2:37:33 PM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
door switch (Dryer Repair)
by Cole B. 8/28/2016 10:26:07 AM(UTC)
How to remove the door switch (part #AP4442085) (Refrigerator & Freezer Repair)
by rannug 4/20/2016 10:12:10 AM(UTC)
wiring for maytag door switch (Dryer Repair)
by macjane94 5/29/2015 10:25:15 AM(UTC)
Door switches not operating properly (Microwave Repair)
by restlesssailor 4/19/2015 12:21:54 PM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
How do I disconnect door switch? (Dryer Repair)
by ocampon 12/12/2014 3:18:51 PM(UTC)
Can't put the freezer door switch back! (Refrigerator & Freezer Repair)
by bzk 5/13/2014 5:22:07 PM(UTC)
2 Pages12>
