Annika
#1 Posted : Tuesday, January 14, 2014 7:32:14 AM(UTC)
Annika
My KitchenAid stand mixer gets stuck while turning when the beater shaft gets to about 11 o'clock. I can manually "bump" it past that point and it goes another circuit before getting stuck again. I think it is a bearing, but which one? Can you help?
MikeWolfes
#2 Posted : Monday, January 27, 2014 8:03:05 PM(UTC)
MikeWolfes
if you can make a repair by your own then you may also check which one is troubling as you do have to open it in all cases, if i am not wrong
cssmotorsports
#3 Posted : Wednesday, January 29, 2014 4:06:26 AM(UTC)
cssmotorsports
I just replaced the worm gear in my mixer that had a worn spot in the gear teeth.. The part is around $40.00 if you don't find anythiong else wrong after it is opened up
