buckeye597
#1 Posted : Sunday, February 17, 2013 4:09:06 PM(UTC)
buckeye597
I have a Maytag Neptune dryer model MCE8000AYW. It will not start.
When I press the Start button, it just makes a clicking sound.
The top portion of the drying cabinet works fine.
The control panel works and the diagnostic code result returns SOL and End (nothing).
I ran a Logic Board Output Self-Test (Lo) and both top and bottom return PASS.
We reset to factory defaults and still nothing.
I opened the front case, cleaned out all the lint.
I removed the Thermal fuse and tested for continuity and there is continuity. I put the thermal fuse back on. I also tested the door switch and the continuity was also good.
Any other testing suggestions or help would be appreciated.
Thank you,
Buckeye 597
mijnomrah
#2 Posted : Monday, November 25, 2013 5:17:16 AM(UTC)
mijnomrah
I'm having the exact same symptoms and test results. Just curious if you figured out what was wrong?
Questioner
#3 Posted : Monday, December 16, 2013 6:48:45 PM(UTC)
Questioner
Is anyone answering this? I have what sounds to be the same problem.
mijnomrah
#4 Posted : Monday, December 16, 2013 6:55:13 PM(UTC)
mijnomrah
I ended up fixing it myself. Both the thermal fuse and heating element needed to be replaced. The heating element is no longer available so I had to use a restring kit which wasn't was hard as I thought it would be. I spent about $80 in parts.
