2 Pages<12
ProfKenn
#11 Posted : Friday, November 22, 2013 3:02:11 AM(UTC)
ProfKenn
Yes, I installed it correctly. It's almost as if there is something keeping the brake from going up or compressing the spring that is inside the brake. May take it apart today and see what is going on inside. The shaft of the transmission will turn without turning the brake.
Appliance Ninja
#12 Posted : Friday, November 22, 2013 6:55:28 AM(UTC)
Appliance Ninja
While not running, you can move the bottom of the agitator in either direction?
ProfKenn
#13 Posted : Friday, November 22, 2013 10:49:54 AM(UTC)
ProfKenn
yes, I can but clockwise is difficult.
Appliance Ninja
#14 Posted : Friday, November 22, 2013 11:03:23 AM(UTC)
Appliance Ninja
It turns easily counterclockwise?
ProfKenn
#15 Posted : Friday, November 22, 2013 11:05:54 AM(UTC)
ProfKenn
Yes, if I grab the upright portion. If I grab the very bottom next to the tub, it turns the whole, tub and all, in either direction.
Appliance Ninja
#16 Posted : Friday, November 22, 2013 11:20:46 AM(UTC)
Appliance Ninja
If you have the lower pulley on correctly, your transmission is likely faulty.
ProfKenn
#17 Posted : Friday, November 22, 2013 11:22:17 AM(UTC)
ProfKenn
OK. Thanks. Yes, I am certain that I installed the pulley correctly. Followed the directions that were included in the part.
Appliance Ninja
#18 Posted : Friday, November 22, 2013 11:23:35 AM(UTC)
Appliance Ninja
Probably time to go washer shopping then....
Maytag washer won't spin fast enough (Washer Repair)
by dster 1/6/2014 7:06:08 AM(UTC)
2 Pages<12
