3 Pages<123>
Bobjones321
#11 Posted : Tuesday, November 19, 2013 7:39:36 PM(UTC)
Bobjones321
The main wash motor runs and both upper and lower wash arms are operating normally, water is heating to around 145 degrees. I let the timer run down after the detergent dispensed and the washer ran its 3 short on off cycles. The washer was idle for almost 40 min then drained and refilled and began the rinse cycle and drained normally at the end of the completed wash cycle. Everything appears normal except the wash cycle. The timer now resets to around 108 min so the new control board did correct the long 144 min cycle issue.
Appliance Ninja
#12 Posted : Wednesday, November 20, 2013 6:12:02 AM(UTC)
Appliance Ninja
The sensor at the link below can modify the cycle. Is that the part you cleaned, referred to in your opening statement?
Bosch 00165279 Aqua-Sensor Assembly - AppliancePartsPros.com
Bobjones321
#13 Posted : Wednesday, November 20, 2013 8:24:30 AM(UTC)
Bobjones321
The sensor I referred to in my opening post was inside the washer under the filters. Most likely the float not a sensor, but I'm not positive. So to answer your question I have not accessed the sensor you referred to in your last post.
Appliance Ninja
#14 Posted : Wednesday, November 20, 2013 8:28:24 AM(UTC)
Appliance Ninja
That sensor is mounted to the bottom of the sump assembly. As water passes through it, it sends a signal to the control about what it "sees." I would remove it and clean it well and see if it makes any difference.
Bobjones321
#15 Posted : Wednesday, November 20, 2013 8:55:50 AM(UTC)
Bobjones321
Any suggestions on how to access the sensor?
Appliance Ninja
#16 Posted : Wednesday, November 20, 2013 9:01:34 AM(UTC)
Appliance Ninja
The page below should help.
Appliance Ninja attached the following image(s):
Bobjones321
#17 Posted : Wednesday, November 20, 2013 10:23:09 AM(UTC)
Bobjones321
Is there a diagnostic test I can run to check for sensor faults or other issues with the dishwasher?
Appliance Ninja
#18 Posted : Wednesday, November 20, 2013 10:25:30 AM(UTC)
Appliance Ninja
I don't have the specific tech sheet for your model, but there may be one behind the lower kick panel, usually on the left side.
Bobjones321
#19 Posted : Thursday, November 21, 2013 6:04:07 AM(UTC)
Bobjones321
Last night I operated the dishwasher in Auto wash (108 min run time) with the same results as before. I then ran it in Regular wash (144 min run time) and it appears to have operated normally, no extended idle periods. However I tested the water temp multiple times and it was not being heated above 120 degrees. In Auto wash the rinse temp is between 140 to 150 degrees. I haven't cleaned the aqua sensor but that is my next step unless you have additional suggestions.
Appliance Ninja
#20 Posted : Thursday, November 21, 2013 6:15:04 AM(UTC)
Appliance Ninja
If the water temp is not increasing, you have another issue. It most often times is due to a faulty connection on the board, but since the board is new, that is not likely. The heater is down below on the right side. Can you test it for continuity?
Guest (16)
Variation on the usual Bosch control board issue (Dishwasher Repair)
by hvandeinse 5/28/2012 9:22:24 AM(UTC)
3 Pages<123>
