JTR1970
#1 Posted : Friday, November 15, 2013 3:25:51 PM(UTC)
JTR1970
I am replacing the machine control electronics assembly on my Whirlpool Cabrio dryer. I have disconnected all of the wires except for two that I cannot for the life of me figure out how to disengage. They are the violet and red wires leading into a tan clip (and connecting to the orange heater relay 2).
A photo is attached.
I've prodded, pulled, and squeezed, and they won't budge. What am I missing?
JTR1970 attached the following image(s):
Appliance Ninja
#2 Posted : Friday, November 15, 2013 3:32:21 PM(UTC)
Appliance Ninja
Those are just spade terminals but I cannot tell if the plastic connector has a lock on it or not. If it does, it would be pretty visible. A flat screwdriver under the connector with a slight twist often times will get it loose with little effort.
JTR1970
#3 Posted : Friday, November 15, 2013 4:23:38 PM(UTC)
JTR1970
Thanks, Ninja. Managed to pry it loose from underneath as you suggested. Up and running again.
Appliance Ninja
#4 Posted : Friday, November 15, 2013 4:26:25 PM(UTC)
Appliance Ninja
Sometimes those spade connectors get very hard to get off. Glad you got it, nice job!
