lenius1
#1 Posted : Monday, September 30, 2013 8:06:14 AM(UTC)
lenius1
Hi,
I have a maytag neptune dryer model mde9700ayw which is in need of a power cord. I have a three prong cord from the washer. It has a black wire a white wire and a green wire. How do I hook it up? There are 3 screw terminals on the dryer. The wires running to the terminals are black, white and red, and it has a green ground wire running from the dryer to the frame. Any help???
Thanks:confused:
#2 Posted : Monday, September 30, 2013 9:25:16 AM(UTC)
You cannot use a washing machine power cord on a dryer.
The wire gauge is too small for the current a dryer uses.
You need to get a dryer power cord.
Make sure the plug end matches the wall receptacle in the house.
You will also have to check the dryer to see if it is hooked up for 3 wire or 4 wire hook-up.
If you go to the Maytag website you should be able to download an install manual for this unit in the support section.
How to wire a 4 prong power cord to an older dryer (Dryer Repair)
by hochoi 7/15/2018 3:00:38 PM(UTC)
Weird power cord behavior -- dangerous? (Refrigerator & Freezer Repair)
by snakestu 2/25/2016 4:45:56 PM(UTC)
Kenmore Dryer - Changed Power Cord & Now Noisy? (Dryer Repair)
by kjcristillo 10/2/2015 4:31:14 PM(UTC)
Need to replace power cord (Oven Repair (including Ranges and Cooktops))
by cwelchj@gmail.com 4/18/2015 4:28:39 AM(UTC)
Whirlpool dryer motor comes on when I plug in power cord (Dryer Repair)
by Nick from Detroit 8/29/2014 3:38:09 PM(UTC)
Power cord replacement A/C fell from window (Heating, Ventilation, and Air Conditioning (HVAC))
by Johnfliesagain 8/19/2013 6:37:53 PM(UTC)
by rdedeaux 9/27/2012 3:23:46 PM(UTC)
power cord (Dishwasher Repair)
by brent32tn 9/4/2012 3:29:15 PM(UTC)
replacing power cord (Trash Compactor Repair)
by Derrell 9/4/2012 3:10:23 PM(UTC)
bosch power cord (Dishwasher Repair)
by jcouzzi 8/9/2012 7:43:24 AM(UTC)
Change a power cord in a Samsung Refrigerator (Refrigerator & Freezer Repair)
by rickim757 1/11/2012 7:27:22 PM(UTC)
power cord had short I fixed the cord and now nothing (Dryer Repair)
by tlh18 11/1/2011 5:10:18 PM(UTC)
replacing Kenmore Washer power cord to ground it, change angle of cord (Washer Repair)
by maddy 6/15/2011 10:46:04 AM(UTC)
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? (Washer Repair)
by maddy 6/15/2011 9:11:07 AM(UTC)
Whirlpool Duet Power Cord (Washer Repair)
by Onedodal 6/15/2011 8:47:26 AM(UTC)
