Pat Ranguette
#1 Posted : Monday, August 26, 2013 5:41:29 PM(UTC)
Pat Ranguette
Just replaced the heat element but sensor dry cycle not working, timed dry cycle does work but have to run 2 - 3 times to get clothes dry. Not sure what to check next.
HumboldtRepairMan
#2 Posted : Monday, August 26, 2013 6:40:58 PM(UTC)
HumboldtRepairMan
First off when you replaced the heat element there's 2 wires going to the moisture bars on the inside front of the unit i bet you didn't reattach those wires, it's a common mistake. Also clean those bars up with a piece of sandpaper or a metal bristle brush they get fabric softener and detergent residue that affects the moisture sensor cycle. Easy way to test if your moisture sensing is working properly, put NO clothes in unit run it for 10-15 minutes if it shuts off by itself it's working properly. Good luck
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
Dryer Problem Again (Dryer Repair)
by dstoliby 7/30/2012 11:37:40 AM(UTC)
