al kopsick
#1 Posted : Sunday, October 8, 2017 11:08:40 AM(UTC)
al kopsick
My dryer stops during the cycle and it seems like the heating element doesn't get hot. I have continuity on the thermal limit switch and I'm the dryer thermal fuse but not on the thermistor. I am hoping that replacing the thermostat will correct the problem. Any ideas?
Pirate111
#2 Posted : Sunday, October 8, 2017 2:17:31 PM(UTC)
Pirate111
As for no heat, Is the heating element broken...(coils)
al kopsick
#3 Posted : Sunday, October 8, 2017 2:52:20 PM(UTC)
al kopsick
Thanks for your quick reply. Turns out the heating element coil is broken. Heats up fine when reconnected. Appreciate the advice.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
Dryer Problem Again (Dryer Repair)
by dstoliby 7/30/2012 11:37:40 AM(UTC)
