Dryer on Laundry Center started making intermittent squeaking noise, but has now become constant when Dryer is running. First thought is that the Drum Bearing is "shot" and needs replacing. Any other possibilities?
Anything is possibly but in most laundry centers it's the rear bearing kit.......check the belt, tensioner, and motor shaft as well as motor movement, also take a good look at the drum make sure it's not warped. Watch you tube video's to help you dismantle and figure it out. Good luck
