LMK
#1 Posted : Sunday, August 18, 2013 2:28:22 PM(UTC)
LMK
I have a 1998 6 burner Thermador Cooktop on which one burner stopped working. Using Gene's suggestion I was able to remove the burner in order to replace the ignition plug by using two crescent wrenches, however after removing the clip and spring I was unable to remove plug. Since the new plug I received from Bosch clearly was much larger than I needed I decided to switch the burner assembly with one of the other five burners that were working properly. To my surprise the old plug had no trouble igniting the other burner but the plug from that burner would not light the first and I lit by match the igniter plugs continue to fire on other burners .
1. Should I replace igniter control?
2. How do i remove ignition plug from burner.
3. Is a proper igniter plug available
LMK
#2 Posted : Sunday, August 18, 2013 3:05:39 PM(UTC)
LMK
Thermador Pro Cooktop Ignition replacement
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 11/20/2022 6:48:33 PM(UTC)
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3/26/2022 5:48:44 AM(UTC)
Thermador cooktop burner keeps clicking after igniting (Oven Repair (including Ranges and Cooktops))
by dcdwyer 8/4/2021 10:48:09 AM(UTC)
HELP: Remove Thermador cooktop (SGVC36G01) top access (Oven Repair (including Ranges and Cooktops))
by jrbarlow22 2/6/2021 7:55:49 AM(UTC)
SGSX365FS/03 Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by mike3000 1/22/2021 5:55:14 AM(UTC)
Thermador Cooktop Ignition Problems (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 1/15/2016 10:56:01 AM(UTC)
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 1/20/2015 8:35:01 AM(UTC)
Thermador Cooktop Griddle Doesn't Heat Properly (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 5/15/2013 12:36:04 PM(UTC)
thermador cooktop problems (Oven Repair (including Ranges and Cooktops))
by billg87 1/12/2013 5:57:14 PM(UTC)
Remove front panel of Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by hloos 12/18/2012 1:57:11 PM(UTC)
Thermador Cooktop Spark Module (Oven Repair (including Ranges and Cooktops))
by randydodd 10/26/2012 2:50:16 PM(UTC)
thermador cooktop halogen burner partially working (Oven Repair (including Ranges and Cooktops))
by judith w 10/20/2012 5:00:09 PM(UTC)
Weak Spark on Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by cwilliamrose 6/5/2012 11:53:46 AM(UTC)
One igniter stopped working on my Thermador cooktop (Oven Repair (including Ranges and Cooktops))
by ingas 3/25/2012 9:25:28 PM(UTC)
Thermador Cooktop XLO Burners (Oven Repair (including Ranges and Cooktops))
by gimidlin 3/20/2012 8:22:44 AM(UTC)
