MyNameIsNate
#1 Posted : Thursday, July 11, 2013 10:21:58 PM(UTC)
MyNameIsNate
Our family fridge died this morning and after a few words and funeral services we hauled it out and went to find a new one. My neighbor/friend had an older electrolux that had been sitting in his garage (unplugged) for over a year, it had been in his home when he bought it. I cleaned it out for the better part of two hours, and I did think to plug it in first and everything turned on so I thought it was fine, but after loading it up I realized: It's not getting cold.
I pulled it out and looked behind and the compressor is pretty warm, the lights come on, but I don't know fridges so I'm not sure where to start looking for the problem. I'd appreciate any pointers you can give me.
Here's the
Owner's Manual
Installation Guide
Factory parts list
I'm really grateful this community exists and I appreciate your help.
richappy
#2 Posted : Friday, July 12, 2013 1:43:10 AM(UTC)
richappy
Is the compressor vibrating?
MyNameIsNate
#3 Posted : Friday, July 12, 2013 5:58:06 AM(UTC)
MyNameIsNate
It seems like it's vibrating a little but it's not exactly running.
Update: I found what seems to be a water reservoir puttyed to the top of the compressor. I filled it and heard it running through the tubes and it seemed like there would be some improvement- the compressor even turned on for a few minutes, but still no cooling.
hannahjo
#4 Posted : Friday, July 12, 2013 10:18:05 PM(UTC)
hannahjo
Try unplugging it for some time and then plug it on. Leave it like that for some time and wait to see the result. If it is still not cooling, get it checked at a reliable refrigerator repair services center asap!
richappy
#5 Posted : Saturday, July 13, 2013 1:11:51 AM(UTC)
richappy
If it started to run, then stopped, you probably have a bad start device on the side of the compressor. If you laid it down while moving and plugged it in soon after up righting, you now have oil trapped in the capillary tube.
MyNameIsNate
#6 Posted : Monday, July 15, 2013 6:55:27 AM(UTC)
MyNameIsNate
Thanks for the suggestions. I unplugged it and let it sit and then when I plugged it back in I realized a couple things:
1. There wasn't enough water in the reservoir to properly circulate through the system.
2. There was a high-pitched whine at the top in back of the freezer.
I added water until everything circulated fine, then I opened up the back of the freezer and found the real culprit: a stuck fan. I cleaned the fan and oiled it, gave it a spin and it started like a charm. Within a day I had my fridge compartment down to 35deg and everything seems fine.
Thanks everyone
