Deborah Lawson
#1 Posted : Monday, June 10, 2013 10:51:29 AM(UTC)
Deborah Lawson
It opens if there is no detergent in the dispensor. Not very useful. I have cleaned the diswasher. I have tried both gell and powdered detergent. No difference. Only opens if empty. Any suggestions before I call for a repairman would be appreciated. I called the Bosch help line and all they could tell me was to call a repairman. They call that a help line?:mad:
Simon / APP Team
#2 Posted : Monday, June 10, 2013 1:25:36 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please, post the complete model number of the unit.
Also, when the dispenser is full of soap, can you open it by pressing the dispenser door latch?
Simon.
Deborah Lawson
#3 Posted : Tuesday, June 11, 2013 4:10:21 AM(UTC)
Deborah Lawson
Model number is: SHU43C02UC/47.
Yes, when it is full I can open it by pressing the dispenser door latch.
Simon / APP Team
#4 Posted : Tuesday, June 11, 2013 10:58:38 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is within the detergent dispenser. Also you should check the wiring harness between the dispenser and control board. Make sure all the connections at the control are good.
There is also a chance, that the control board is malfunctioning. But this part is no longer available.
Give it a shot in replacing the dispenser
Part number: 488964
Part number: 488964
Post the results.
Simon.
Deborah Lawson
#5 Posted : Tuesday, June 11, 2013 11:37:27 AM(UTC)
Deborah Lawson
but why would it open when there is no product in it?
Simon / APP Team
#6 Posted : Tuesday, June 11, 2013 12:38:47 PM(UTC)
Simon / APP Team
Groups: APP Team
There is no logical explanation to this problem, except the actuator is weak.
If the replacing of the dispenser would not help, you can return the part back to APP.
Post the results.
Simon.
Guest (7)
