Fixit Dad
#1 Posted : Thursday, May 23, 2013 4:26:49 PM(UTC)
Fixit Dad
Trying to fix my daughters washer. It will not drain or spin. It fills, aggitates and then does nothing. You can hear it clicking through the entire cycle but nothing more happens. You turn it to just before 'spin' and let it advance to 'spin' on its own and nothing happens. No clunks, nothing like the motor is trying to spin, nothing. It is not the lid switch. I thought it was and bought a new one and it did not help. Again, the dial moves through all the cycles, but it will not drain or spin. I manually drained it, so it is not clogged.
Any ideas.
fairbank56
#2 Posted : Thursday, May 23, 2013 5:06:14 PM(UTC)
fairbank56
Sounds like a faulty timer. Can you post a clear photo of the wiring diagram? Should be pasted to left side of inside of back panel behind control panel and cabinet. Open control panel and remove cabinet to gain access.
Eric
fairbank56
#3 Posted : Thursday, May 23, 2013 5:41:13 PM(UTC)
fairbank56
Got a copy of your wiring diagram. If you hear no noise at all from the drive motor as timer advances through drain/spin, then it appears you have a faulty timer.
Eric
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
Maytag Washer Will Not Drain or Spin during White or Color Cycle (Washer Repair)
by ametz69 11/6/2012 5:52:41 PM(UTC)
Washer will not drain or spin (Washer Repair)
by apprik 6/20/2012 5:39:48 AM(UTC)
Top loan washer will not drain or spin (Washer Repair)
by Tom Roberts 4/26/2012 9:03:03 AM(UTC)
LG washer will not drain or spin (Washer Repair)
by rangers02 10/12/2011 2:51:22 PM(UTC)
Roper washer will not drain or spin? (Washer Repair)
by Burns5150 9/3/2011 6:50:17 AM(UTC)
Washer will not drain or spin on final rinse. (Washer Repair)
by link888 3/24/2011 7:38:52 AM(UTC)
by link888 3/24/2011 7:32:23 AM(UTC)
Washer will not drain or spin. (Washer Repair)
by albouldin 12/3/2010 9:21:23 AM(UTC)
by RHUTCH 8/17/2009 2:57:11 PM(UTC)
Whirlpool washer will not drain or spin. Is it the lid switch? (Washer Repair)
by conramana 6/10/2009 7:48:12 PM(UTC)
whirlpool washer will not drain or spin (Washer Repair)
by llbishop7@cs.com 5/4/2009 8:47:22 AM(UTC)
Washer will not drain or spin when loaded (Washer Repair)
by Roc1966 12/11/2008 3:37:57 AM(UTC)
