Freezer not working. Replace run capacitor, freezer ran for few seconds then stopped. Is the start relay a probable fix?
Groups: APP Team
Hi. It could be bad compressor or start relay and overload. You can check continuity between the three compressors pins and if they are OK - replace the start components. It looks like the original part is not available. You can get the Part number: RCO410
and check if the freezer will run. Keep in mind that this devise may damage the compressor after some time if left installed. Simon.
