kimber9369
#1 Posted : Monday, May 13, 2013 10:08:17 AM(UTC)
kimber9369
My gas dryer is no longer heating. Could it just be the vents need to be vacuumed or a part fixed?
Simon / APP Team
#2 Posted : Monday, May 13, 2013 11:35:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If it takes too long to dry, then it's a restricted vent, but if there is no heat at all you should run the troubleshooting using a multimeter. By testing the parts before replacing you may save money and time.
Check if the ignitor glows, if not check the thermal fuse (it should have continuity).
The thermal fuse is #10 on the diagram 05-Motor Drive parts for Maytag MDG7400AWW - AppliancePartsPros.com
Post the results.
Simon.
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
Maytag gas dryer not heating (Dryer Repair)
by jpono 12/11/2011 5:31:23 PM(UTC)
