wilma
#1 Posted : Sunday, December 9, 2007 4:46:20 PM(UTC)
wilma
went to preheat oven and there's no heat, broiler is working though can you give me some insight cuold this be the igniter in the lower part of the oven just needs replaced and how much is the part
#2 Posted : Monday, December 10, 2007 12:27:50 PM(UTC)
Unplug the bake igniter and check for 120V coming to the igniter while the oven is set on Bake.
If there is 120V then the igniter has to be replaced.
If there is no 120V then the control board is bad and has to be replaced.
- The part number for the bake igniter AP3455537
To find the right part number for the control board I need the serial number of the range.
lorriehenry
#3 Posted : Saturday, December 29, 2007 4:16:01 PM(UTC)
lorriehenry
I have a GE JGBP30 range. Its gas, the burners work on the top, the broiler works fine but oven will not lite. Worked just fine yesterday.. please help? Thanks lorrie
lorriehenry
#4 Posted : Saturday, December 29, 2007 4:18:33 PM(UTC)
lorriehenry
GE JGBP30 gas range. The burners work on the top, the broiler works also. We used the oven yesterday and it worked fine. Now it will not lite? Please help could it be the igniter and how would we test it!
#5 Posted : Sunday, December 30, 2007 7:51:58 PM(UTC)
Most likely the problem is the igniter.
You can read the post on top of yours to get the test instructions.
In order to find the right part number for the igniter (or other parts) I need the complete model number of the range.
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
