liang
#1 Posted : Tuesday, April 21, 2009 2:31:03 PM(UTC)
liang
I need help of finding the correct part to fix the squeaky noise coming from near the door, also a rubbing noise associate with it, thanks!
applianceman
#2 Posted : Tuesday, April 21, 2009 5:17:37 PM(UTC)
applianceman
First disconnect power from dryer then remove the top by removing the screws inside the door pointing up. Then remove then remove the screws inside the case pointing forward. Once done the front should lean forward and lift up and out of the way. There are five bearings that commonly cause these dryers to squeal. Four slides on the front that the drum glides on and one sleeve bearing on the drum shaft on the back of the drum. To get to the sleeve bearing remove the drum by unhooking the belt and sliding the drum forward enough to replace the bearing. for more on this visit GE Dryer Noisy Repair Guide
liang
#3 Posted : Tuesday, April 21, 2009 5:27:09 PM(UTC)
liang
Thank you for the quick reply, I will try to follow through as instructed.
Squeaky Dryer (Dryer Repair)
by luaumaster 8/21/2013 3:50:33 PM(UTC)
by jervisdj 7/2/2013 4:43:16 PM(UTC)
squeaky dryer (Dryer Repair)
by frankn 2/6/2012 7:35:57 PM(UTC)
by lgibson 9/9/2010 2:58:46 PM(UTC)
Repair of squeaky dryer (Dryer Repair)
by sbuckley@dtec.com 9/9/2010 11:36:44 AM(UTC)
very LOUD squeaky dryer (Dryer Repair)
by sdvia 8/26/2010 12:13:34 PM(UTC)
Squeaky dryer: which part(s) do I need (Dryer Repair)
by JerzyL 5/5/2010 7:35:02 AM(UTC)
Kenmore Squeaky Dryer (Dryer Repair)
by RussAwana 5/4/2010 8:00:57 PM(UTC)
Squeaky dryer (Dryer Repair)
by Bill in Mass. 11/13/2009 11:05:58 AM(UTC)
Loud Squeaky Dryer Noise (Dryer Repair)
by Hart1092 11/9/2009 2:54:19 PM(UTC)
by Alanna 9/18/2009 8:20:07 AM(UTC)
by SupermanRepairman 9/17/2009 5:31:27 PM(UTC)
by linus410 9/13/2009 7:54:27 AM(UTC)
by Kruldaddy 9/6/2009 9:00:42 AM(UTC)
by fiorillo 5/20/2009 6:21:27 PM(UTC)
