Groups: APP Team
Hi, Steve.
Please describe (no offense) how do you check the voltage at the ignitor.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, Steve.
Simon. insert each probe into machine side plug, after setting meter to voltage, turn machine on, obtained reading of 123v, as instructed by certified tech on phone.
Groups: APP Team
In that case you need to replace the ignitor. If there is 120 VAC at the plug and you put in a good ignitor it should glow!
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) In that case you need to replace the ignitor. If there is 120 VAC at the plug and you put in a good ignitor it should glow!
Simon. hi Simon. I just bought it Friday, it arrived Saturday, and I installed it shortly after it arrived. I called back when I realized it still wasn't working.
Ok, well, this issue is resolved! I hope. It appears that the dryer control board had a bad component. Of course, as I am not an electronic circuitry guy, I have no way of repairing it. Grrr! Soldering isn't the issue, it's figuring out which one is bad.
Steve DB I have a similar problem. No heat --the ignitor does not glow --nothing. No gas flow--Fuses all appear to be OK. Gas valve does not open to allow gas to flow . What else can be checked.??? What did you find on your unit that was the problem ? Need help.
