shutupnlemedrive
#1 Posted : Monday, April 20, 2009 3:40:10 PM(UTC)
shutupnlemedrive
I just bought a house and the microwave (JVM1851BH02) doesn't heat I tried replacing the HV diode but no luck, also Themostat(#79) has no continuity while all the others have continuity. I am wondering if it should have continuity at room tempature or not? Its probable the Magnetron but just wanted to check before I spent the money. I also checked the door switches and they check out ok.
Thanks in advance,
Chad
TechnicianBrian
#2 Posted : Monday, April 20, 2009 4:23:32 PM(UTC)
TechnicianBrian
If you have done all those checks, it may be the magnetron, but I would first verify 120vac to the input of the high voltage transformer first. If you have it, then at least we know its a HV problem. As for the thermostat (#79) that would most likely be normal open and closes to turn on the blower to help cool the unit when the range below is in use.
Runs 3Min Stops-OR-Runs & Doesn't heat Samsung Dryer DV42H5000EW/A3-0000 (Dryer Repair)
by Guest 2/18/2022 11:57:14 AM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
Lower Oven doesn't heat properly (Oven Repair (including Ranges and Cooktops))
by Softballfan 4/16/2016 1:45:41 PM(UTC)
*** HELP!! GE Dryer Doesn't Heat *** (Dryer Repair)
by SkyNet3 2/25/2016 12:46:10 PM(UTC)
Bake reaches preheat temp and doesn't heat again (Oven Repair (including Ranges and Cooktops))
by D_Hicks 12/13/2015 5:07:43 PM(UTC)
microwave fan either runs nonstop or doesn't heat when replacing thermostat sensors (Microwave Repair)
by seannorek 9/25/2015 4:09:21 PM(UTC)
Heating element dries dishes but doesn't heat water?? (Dishwasher Repair)
by Paul_illinois 6/16/2014 7:53:28 PM(UTC)
Electric Dryer runs but doesn't heat (Dryer Repair)
by yoamocuy 10/8/2013 3:43:14 PM(UTC)
Maytag microwave doesn't heat (Microwave Repair)
by kbooms 8/21/2013 6:01:09 PM(UTC)
Microwave counts down, light comes on, but doesn't heat (Microwave Repair)
by rmcmican 7/2/2013 5:41:18 AM(UTC)
Thermador Cooktop Griddle Doesn't Heat Properly (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 5/15/2013 12:36:04 PM(UTC)
fridgidaire oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by debshroom 5/8/2013 7:15:43 AM(UTC)
MWO runs but doesn't heat (Microwave Repair)
by mwohelper 4/18/2013 8:01:05 PM(UTC)
Dryer doesn't heat (Dryer Repair)
by SteveDB 4/16/2013 10:47:38 AM(UTC)
