21 Pages«<1718192021>
#181 Posted : Wednesday, April 3, 2013 11:10:58 AM(UTC)
Sounds like the fan motor has gone bad.
- The fan motor Part number: WB26X10264
Tucson Alan
#182 Posted : Wednesday, April 3, 2013 3:07:49 PM(UTC)
Tucson Alan
Yup, thats what I figured, ordered one today.
#183 Posted : Wednesday, April 3, 2013 4:39:52 PM(UTC)
Keep us posted please.
Tucson Alan
#184 Posted : Friday, April 5, 2013 12:47:16 PM(UTC)
Tucson Alan
Received fan today and installed it. Oven up and running. Spec sheet had info on thermal cutoff switch when fan fails. Just wish your shipping dept. had packed fan a little better. Broken plastic frame and trim pieces. Lucky it did not affect performance.
Alan :)
#185 Posted : Friday, April 5, 2013 3:57:01 PM(UTC)
You are welcome Alan. I'm glad it's up and running.
Regarding broken package you have to talk to the APP customer service. I do not work for APP. I'm just helping people like you as a volunteer.
bravo2510
#186 Posted : Monday, April 29, 2013 1:32:21 AM(UTC)
bravo2510
This is very informative post. I came to know about the errors and this will surely help me in future as I am mad about cooking I usually go through some errors. Thank you
hannahjo
#187 Posted : Friday, July 12, 2013 1:56:12 AM(UTC)
hannahjo
Very helpful post! Thanks much for the oven repair tip!
martymande
#188 Posted : Friday, July 12, 2013 2:29:29 AM(UTC)
martymande
My Thermador PDR366ZS oven's blue heat lamp is flashing 4 times, the blue heat lamp is out. I need to replace that so I can see the second part of code. I cannot get the front panel off are there instructions or video to show this?
Also how do you know if it is an E or an F code?
sstark
#189 Posted : Tuesday, October 1, 2013 10:00:08 AM(UTC)
sstark
Originally Posted by: Admin / APP Team Go to Quoted Post
.... Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands....
I must be blind. I cannot find the "error code page" that has the "simple test." Could you provide a link?
Thanks!
kendfig11
#190 Posted : Wednesday, December 4, 2013 5:45:01 AM(UTC)
kendfig11
I have Maytag oven. Model number is CHE9800BCE. It's over 10 years old.
Three days ago, the bake element started to burn. Within a few minutes, the oven flashed the F1 error code. We turned off power to the oven and ordered a new bake element from AppliancePartsPros. I put that in yesterday with no problems.
When we turned on the power and attempted to heat up the oven using the bake function, the F1 error code flashed after two minutes. The bake element did not heat up at all. We tried this several times.
Even when we turn on power again and do not attempt to heat up the oven, the F1 error flashes after a couple minutes. And it continues to return a few minutes after pressing Cancel. The broil element also does not work. The burn elements on the top do still work.
Is there something wrong, then, with the touch pad as well? Could that have failed just at the same time that the bake element burned out?
The part is 12001607 (AP4009447), which does not appear to be carried by AppliancePartsPros.
Guest (8)
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
