Texasdiyer
#1 Posted : Monday, March 25, 2013 5:10:12 AM(UTC)
Texasdiyer
Inside the washing machine cabinet, attached to the frame, is a small (about 2") brass pin with a hole in end (looks like for a cotter pin) in a clear plastic holder.
What is it ?
It appears to perhaps be a "special tool" as opposed to a part (I could not find it on the 7 parts diagrams) maybe for use to keep something (tub?) from spinning while removing a nut or something.
Thanks very much.
fairbank56
#2 Posted : Monday, March 25, 2013 5:23:25 AM(UTC)
fairbank56
Those are shipping pins. They are inserted during manufacturing to keep the suspension system from getting all out of wack during shipping. Small clips are inserted into the hole to keep them in place. The clips have a small strap attached to them that exits the back of the machine. When the washer is first installed, the installer yanks the strap out pulling the clips and the pins fall into the little cups. There should be two of them.
Eric
Texasdiyer
#3 Posted : Monday, March 25, 2013 2:23:28 PM(UTC)
Texasdiyer
FB56 - you rock dude ! Thank you and I mean that. I didn't think they were "in-use" and so when I had the cabinet off this weekend I removed them and the cup. Although I did only remove one. I will have to check next time I have cabinet open for the other one. I just wanted to make sure it/they were not some sort of counterweight or anythiny important. Thx again very much.
tcattani
#4 Posted : Tuesday, March 10, 2015 2:53:22 PM(UTC)
tcattani
Thank you so much! I was sure the machine was going to self-destruct! You made my day!
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
Belarus Guest 4/23/2023 7:29:26 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Whirlpool washing machine destroying water pumps (Washer Repair)
by mjcarb 8/30/2016 11:53:49 AM(UTC)
whirlpool washing machine (Washer Repair)
by gman2233 5/27/2015 6:32:08 PM(UTC)
Whirlpool washing machine drain/spin noise (Washer Repair)
by wlakeberry84 6/24/2014 8:25:04 PM(UTC)
by tungkiu 12/5/2013 3:42:15 PM(UTC)
Whirlpool Washing Machine Plastic Washers (Washer Repair)
by ohcableman 7/4/2013 10:28:31 AM(UTC)
whirlpool washing machine will not spin out everytime (Washer Repair)
by rdgiles1 4/16/2013 6:50:00 AM(UTC)
Whirlpool Washing Machine Agitates for the entire cycle (Washer Repair)
by swkucera 12/4/2012 5:09:02 AM(UTC)
Whirlpool Washing Machine (Washer Repair)
by edie590 8/16/2012 8:29:21 AM(UTC)
by allantag 8/2/2012 12:58:01 PM(UTC)
by sunshine123 9/3/2011 8:05:34 PM(UTC)
Whirlpool washing machine LSQ9010KQ0 timer replace instrucions (Washer Repair)
by PlankOwner 12/29/2010 8:59:42 PM(UTC)
