2 Pages12>
pladaaad
#1 Posted : 12 years ago
pladaaad
My Whirlpool GEW9200 Dryer drum will not stop spinning if the door is closed, even with the control panel off (no LEDs lit). I'm assuming it is the control board, but was wondering if there are any disgnostics I can run to confirm the issue. Whirlpool documentation is no help.
#2 Posted : 12 years ago
Your model number seems to be missing several digits at the end.
Please check it.
pladaaad
#3 Posted : 12 years ago
pladaaad
Still won't stop spinning.:confused: I now just leave the door open when not in use.
#4 Posted : 12 years ago
Parts for Whirlpool GEW9200LW1 Dryer - AppliancePartsPros.com
You could check the control panel/keypad but it does sound like the control board is toast.
File Attachment(s):
GEW9200.pdf (335kb) downloaded 9 time(s).
pladaaad
#5 Posted : 12 years ago
pladaaad
Thanks Denman, but already had the tech sheet. Test #5 has all scenarios except if the control panel is working. Still have no way to diagnose the control board. Guess I have to buy a new one to test.
#6 Posted : 12 years ago
Basically that is what you have to do.
Everything else seems to check out OK so all that is left is the control board.
If you order from AppliancePartsPros they will allow you to return the board if it does not fix your problem.
Please see teir return policy.
pladaaad
#7 Posted : 12 years ago
pladaaad
Replacing the control board fixed the problem. The relay for the motor was shorted in the closed position.
#8 Posted : 12 years ago
Glad to hear that you got it fixed.
CARSAN
#9 Posted : 11 years ago
CARSAN
thanks for the posting just reading it found my solution!!!
CARSAN
#10 Posted : 11 years ago
CARSAN
:) thanks for the posting just reading it found my solution!!!
Dryer drum won't stop spinning (Dryer Repair)
by Serpent 11 years ago
2 Pages12>
