2 Pages12>
pladaaad
#1 Posted : Saturday, February 16, 2013 11:10:23 AM(UTC)
pladaaad
My Whirlpool GEW9200 Dryer drum will not stop spinning if the door is closed, even with the control panel off (no LEDs lit). I'm assuming it is the control board, but was wondering if there are any disgnostics I can run to confirm the issue. Whirlpool documentation is no help.
#2 Posted : Tuesday, February 19, 2013 2:34:48 AM(UTC)
Your model number seems to be missing several digits at the end.
Please check it.
pladaaad
#3 Posted : Tuesday, February 19, 2013 5:14:35 AM(UTC)
pladaaad
Still won't stop spinning.:confused: I now just leave the door open when not in use.
#4 Posted : Thursday, February 21, 2013 1:02:37 AM(UTC)
Parts for Whirlpool GEW9200LW1 Dryer - AppliancePartsPros.com
You could check the control panel/keypad but it does sound like the control board is toast.
File Attachment(s):
GEW9200.pdf (335kb) downloaded 9 time(s).
pladaaad
#5 Posted : Thursday, February 21, 2013 5:15:43 AM(UTC)
pladaaad
Thanks Denman, but already had the tech sheet. Test #5 has all scenarios except if the control panel is working. Still have no way to diagnose the control board. Guess I have to buy a new one to test.
#6 Posted : Thursday, February 21, 2013 9:28:56 AM(UTC)
Basically that is what you have to do.
Everything else seems to check out OK so all that is left is the control board.
If you order from AppliancePartsPros they will allow you to return the board if it does not fix your problem.
Please see teir return policy.
pladaaad
#7 Posted : Saturday, March 2, 2013 1:20:54 PM(UTC)
pladaaad
Replacing the control board fixed the problem. The relay for the motor was shorted in the closed position.
#8 Posted : Saturday, March 2, 2013 2:16:54 PM(UTC)
Glad to hear that you got it fixed.
CARSAN
#9 Posted : Wednesday, March 12, 2014 6:48:19 PM(UTC)
CARSAN
thanks for the posting just reading it found my solution!!!
CARSAN
#10 Posted : Wednesday, March 12, 2014 6:51:27 PM(UTC)
CARSAN
:) thanks for the posting just reading it found my solution!!!
Dryer drum won't stop spinning (Dryer Repair)
by Serpent 2/25/2014 1:48:58 PM(UTC)
2 Pages12>
