joestehlingq
#1 Posted : 12 years ago
joestehlingq
Trying to diagnose washer not tumble, I cannot find out how to access the Motor Control. There is only one access panel in the rear.
#2 Posted : 12 years ago
What is the complete model number of the washer?
joestehlingq
#3 Posted : 12 years ago
joestehlingq
MAH 4000AWW.
joestehlingq
#4 Posted : 12 years ago
joestehlingq
I finally received a repair manual and solved my problem. Thank you for your response.
How can I delete this thread?
joestehlingq
#5 Posted : 12 years ago
joestehlingq
#6 Posted : 12 years ago
Remove the door and the front panel as described in the attached file. Install the door back so you will be able to use the washer.
Perform the motor and the motor control board tests as instructed in the attached file.
Here are the breakdown diagrams and Parts for Maytag MAH4000AWW Washer - AppliancePartsPros.com
File Attachment(s):
Door and front panel removal.doc (136kb) downloaded 5 time(s).
#7 Posted : 12 years ago
I did not see your last posts. You can not delete it.
joestehlingq
#8 Posted : 12 years ago
joestehlingq
Thanx for the help. This is perfect.
