joestehlingq
#1 Posted : Monday, February 11, 2013 2:03:02 PM(UTC)
joestehlingq
Trying to diagnose washer not tumble, I cannot find out how to access the Motor Control. There is only one access panel in the rear.
#2 Posted : Tuesday, February 12, 2013 2:06:35 PM(UTC)
What is the complete model number of the washer?
joestehlingq
#3 Posted : Tuesday, February 12, 2013 6:35:58 PM(UTC)
joestehlingq
MAH 4000AWW.
joestehlingq
#4 Posted : Wednesday, February 13, 2013 2:56:49 PM(UTC)
joestehlingq
I finally received a repair manual and solved my problem. Thank you for your response.
How can I delete this thread?
joestehlingq
#5 Posted : Wednesday, February 13, 2013 2:56:49 PM(UTC)
joestehlingq
#6 Posted : Wednesday, February 13, 2013 3:20:19 PM(UTC)
Remove the door and the front panel as described in the attached file. Install the door back so you will be able to use the washer.
Perform the motor and the motor control board tests as instructed in the attached file.
Here are the breakdown diagrams and Parts for Maytag MAH4000AWW Washer - AppliancePartsPros.com
File Attachment(s):
Door and front panel removal.doc (136kb) downloaded 5 time(s).
#7 Posted : Wednesday, February 13, 2013 3:22:08 PM(UTC)
I did not see your last posts. You can not delete it.
joestehlingq
#8 Posted : Wednesday, February 13, 2013 5:01:58 PM(UTC)
joestehlingq
Thanx for the help. This is perfect.
