How do you tell if your heating element is bad. I have inspected it and found a burn mark. Would that be the golden sign? BorisP attached the following image(s):
Hello Boris, Most likely it's bad but the best way to confirm it is to check it with an ohmmeter for continuity. - The heating element Part number: W10134009
Originally Posted by: Gene Hello Boris, Most likely it's bad but the best way to confirm it is to check it with an ohmmeter for continuity. - The heating element Part number: W10134009
Gene, Thank you, I ordered the part. Boris
You are welcome Boris. Keep us posted.
